Can my users post direct from my pages
#1
how can i enable my users to comment direct on my pages and have the post and related replies appear on the page (as well as in the forum). Hosting is adobe business catalyst so no serverside coding allowed on the site but i can use a middleman server to do the authorisation. Can I do that with the api?
(Robin Ward) #2
There is no way to embed Discourse posting capabilities in static sites. You can only embed posts from a Discourse instance with a “Comment” button that sends the user over.
#3
OK looks like I need to move servers. With php or node what can I do?
(Sam Saffron) #4
I am not sure I am following your question, can you take a step back and explain the full problem you are facing.
(Volkan Unsal) #5
You could probably use the API if you don’t mind rendering the posts and comments yourself. All you need to do is to enable the CORS for the domain of your site under settings.
