Can one auto-generate a post?
(christine from particle) #1
Can one auto-generate a post, either through an existing plugin or through a ruby script or sql? If so what is the syntax? I’d love for people to get a PM when they get a badge for example.
(Jeff Atwood) #2
Yes, I believe @techapj can point you to the sample.
You can also use querystring to pre-fill a post.
(Sander Datema) #3
This could be the bot you’re looking for…
https://github.com/discourse/try-bot
(Arpit Jalan) #4
See this API sample for creating a new topic:
(christine from particle) #5
Hey, I think those are the bots (and api refs) I’m looking for!
Thanks, y’all!
(christine from particle) #6
Is it a complicated process to make the autogenerated post a PM?
(Kane York) #7
No. I think there’s an archetype parameter? Open your browser’s dev tools and try creating a private message to see what your code is supposed to do.
(christine from particle) #8
Thanks everyone. I have the basics of this working. Now I’d love to have these PMs send in response to certain actions, like particular custom badges or helpful flags. I noticed that the try-bot plugin is basically listening for a post_created event. Are there similar events for badges and flags?
(Kane York) #9
Nope, those would need to be added :slight_smile:
(christine from particle) #10
Ah, I thought maybe they might!
I think I see the place where I could trigger the PM, but to maximize modularity I’ve been asked to try to do this in a plugin. Whatcha think? Impossible?
