Can we add tag by comment tags?
(Sora &\) #1
User normal can’t edit tag other user, but they wanna tag via comment same facebook. Later, they can search easy. Same keyword inorder search
Can we do that?
(Dave McClure) #2
A thought/work-around: Using groups as "tags"
(Joe) #3
As far as I know the answer is no.
You cannot add tags to a topic based on posts / comments / replies to the topic. The topic itself has to be edited.
Discourse uses topic “tags” for the purpose of identification / organization. They are labels for topics
What you described on Facebook comments is hashtags - which are also used for identification / organization but are still a bit different from tags.
Discourse does not support #hashtags by default. It might be possible to write a plugin that makes that work.
(Sora &\) #4
Tks @lll my mind mean hastag :slight_smile:
