Cannot backslash-escape left angle bracket < in links
(Kane York) #1
If I place a lone < in a link title, the remaining text on the line is removed.
Lorem [foo <link bar](//null) dolores becomes:
Lorem foo <link bar dolores
which is quite very wrong.
Attempting to use a \ to markdown-escape it did not work:
Lorem [foo \<link bar](//null) dolores becomes
If I try closing the tag:
Lorem [foo <link> bar](//null) dolores becomes
Lorem foo bar dolores
Using entities seems to work:
Lorem [foo &lt;link bar](//null) dolores
But that makes for a very ugly source view.
(Konrad Borowski) #2
In original Markdown, \< doesn’t mean &lt; (rather, it means \<). However, I could find prior art (GitHub Flavored Markdown), so perhaps that’s a good argument why \< should work like &lt;. The second argument would be that parsing it like \< doesn’t make any sense.
(Aahan Krish) #3
I’d consider this a bug as well.
Lorem [foo \<link bar](http://google.com) dolores should result in Lorem <a href="http://google.com">foo \<link bar</a> dolores, which means the end result will still be:
And that’s because you are using < instead of its HTML entity &lt;. But that’s not my point. Discourse is parsing the markdown to this:
Lorem <a href="http://google.com">foo \ dolores</a>
Therefore, it’s yet another (edge case) bug in the new parser. @eviltrout is it a good idea to ping you everytime there’s a bug in the parser, or are you going to find it anyway? (I mean, I don’t want to take it to a point where it gets irritating to you. :wink: )
(Robin Ward) #4
I’m not sure it’s valid markdown to put a < inside a link like that. I checked against PageDown on Stack Overflow and it has the same behaviour as us, so I don’t think it’s a regression in my parser.
This one seems really edge-casey, I might delay on it and see how many are frustrated by it. In the meantime, a workaround is to just use a regular link. Or a bbcode style link. Both will work!
(Jeff Atwood) #5
http://johnmacfarlane.net/babelmark2/?text=Lorem+[foo+<link+bar](%2F%2Fnull)+dolores
Consensus is this should produce
<p>Lorem <a href="//null">foo &lt;link bar</a> dolores</p>
(Jeff Atwood) #6
Looks correct to me now.
(Jeff Atwood) #7
