Cannot open a mailto link inside a post
(Miguel Hurtado) #1
Hi there, I’m using Discourse 1.6.0.beta2.
I have notice that on new post mailto links won’t open correctly. They are redirected to a track link script that doesn’t open the default email client. The url of the script is this: https://meta.discourse.org/clicks/track?url=mailto%3Aasdf%40asdf.com&post_id=187986&topic_id=43031 (replace meta.discourse.org with the installation url).
This doesn’t seems to affect posts that are about two weeks old, just new ones. Examples of this behavior can been seen here:
Can't link emails Email link fails.
Can't create mailto links in posts Email link works.
In my installation I have “track external right clicks” disabled, and it has always been like that.
(Jeff Atwood) #2
Are you doing it this way?
name@example.com
<name@example.com>
or this way?
name@example.com
<a href="mailto:name@example.com">name@example.com</a>
Aha, I see what you mean. Probably a bug we should fix. @techapj can you add to your list?
(Miguel Hurtado) #3
Both ways, they all fail.
(Arpit Jalan) #4
Fixed via:
(Arpit Jalan) #5
