Cannot use Ctrl-R to insert horizontal rule
(Barneedhar Vigneshwar) #1
So, I am used to inserting horizontal rule with Ctrl-R on Stack Exchange. It seems like discourse supports that shortcut too. But for now, it only refreshes the page even when the entry box is active.
Surely a bug no?
(NanoGeek) #2
Also, on a Mac you have issues as Cmd+R is the page refresh… And it is not overridden
(Jeff Atwood) #3
Yeah, I think the issue is that Ctrl+R is refresh in some browsers and as @NanoGeek noted cannot be overridden.
The other shortcuts seem to work:
Ctrl+Q is blockquoe
Ctrl+B is bold
etc. I agree that Ctrl+R works on meta.stackoverflow’s editor though, which is theoretically the same PageDown so… odd.
(TechnoBear) #4
Any progress on fixing this?
Ctrl + R is listed on the editor tooltip as the shortcut for HR, but in Firefox and Chromium on Ubuntu, it just refreshes the page. (I haven’t tested other OS/browsers.)
Either change the shortcut or remove the tooltip would seem to be better than the status quo, which is just plain confusing.
(Sam Saffron) #5
Let’s remove the tip, to be honest it’s not something that really helps much
(Sam Saffron) #6
This is now ctrlaltr , so everything is working right
(Sam Saffron) #7
