Can't able to install plugins, whats the problem?
I tried to install plugins as shown here in support posts.
but it showing me an error and after that forum not loading
how to fix this?
and how to install plugin exactly? any wrong i made while installing plugin?
this is how i added git url
this is what occurs after rebuild
The indentation seems to be broken, the yaml file has a specific structure, if you add a space or use the tab or do not respect this structure the file will be broken and unreadable.
As you can see in your image sitemap and adplugin are not aligned to the docker manager
THe best thing to do is to copy the exiting clone line and paste it immediately below and edit it with the new path. That minimizes the likelihood you’ll get the wrong spacing.
There is a How to guide on Plugin that can help Install Plugins in Discourse
