Can't find 'newuser_max_images'
(Lars Zimmermann) #1
Sorry for bothering you with this. But I looked in every setting twice but I want to change the maximum number of images a new user can upload as described here.
But I can’t find the newuser_max_images in the admin panel.
(OG) #2
Use Settings and filter by text… It is there…
(Joshua Rosenfeld) #3
Just to double check, what version of Discourse are you running?
(Lars Zimmermann) #4
Hi, I found it. It is in ‘Posting’.
(I am running the latest version.)
(Jay Pfaffman) #5
As more people start running stable, it’s going to be more important for howto documents to be explicit about what version the feature was added.
(Jeff Atwood) #6
In this case, this setting has existed since 2013.
(Jay Pfaffman) #7
Perhaps not a good example. :slight_smile:
