Can't find pinned banner
(Mark Devlin) #1
Hi, I’m a new user. Site is http://totalbikers.com I have two problems
  1. I can’t get pin the welcome message to the top of the site. It appears in the uncategorized category.
  2. I don’t seem to be able to make a banner pin at the top of the category. Has this functionality been replaced by the Category Logo Image in the categories settings?
Thanks for your help!
(Régis Hanol) #4
Here’s what the modal says when you try to “pin” a topic:
  • Pinning a topic, will make it appear at the top of the topics lists of it’s category.
  • Globally pinning a topic, will make it appear at the top of all the topics lists.
  • Making a topic a banner, will make it appear at the top of all pages.
(Jeff Atwood) #5
Er… what? I’m not really following what you said above?
Ok re-reading this a few times;
  1. Looks like you did not select pin global
  2. There is no concept of a banner that is per-category – banner is all-site. You can of course pin to the category.
(Mark Devlin) #6
  1. It is pinned globally :confounded:
Sorry, but the banner, pinned banner, banner is all-site distinctions are lost on me. Would you mind clarifying/
(Mark Devlin) #7
Does anyone have any ideas or clarifications?
(Régis Hanol) #8
Re-open the topic, click the pin topic button and chose pin globally in the modal.
(Mark Devlin) #9
Hi, I did all that and it still does not work. However, I think I found the problem:
The Global Pin will only work if a category is selected. But it will not work with the 'Uncategorized" category. Is this a bug?
(Jeff Atwood) #10
Not so – I just globally pinned a topic with no category on try.discourse.org … see for yourself:
