Cant install Advertising Plugin for Discourse
(Cheng Trang) #1
I install Advertising Plugin follow the instructions GitHub - discourse/discourse-adplugin: Official Discourse Advertising Plugin. Install & Start Serving Ads on Your Discourse Forum
But plugin not add Discourse.
This is my app.yml file.
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone https://github.com/discourse/discourse-adplugin.git
Please help me.Tks!
(Bas van Leeuwen) #2
Can you expand a bit on this?
Why is it not added? How did you conclude that it wasn’t added? What have you tried? Have you tried to install another plugin?
(Cheng Trang) #3
I not found config Google adsense on Setting
(Bas van Leeuwen) #4
Do you see the plugin in the Plugin tab? Is it enabled?
(Cheng Trang) #5
I not found Adv Plugin in the Plugin tab .
I installed step by step of guide :GitHub - discourse/discourse-adplugin: Official Discourse Advertising Plugin. Install & Start Serving Ads on Your Discourse Forum
(Bas van Leeuwen) #6
Did you rebuild?
During that step the forums should be down for a few minutes, did that happen?
Can you try to add a different plugin and see if that does show up?
