Can't nominate admins or moderators due to import
(Cy) #1
Hello,
I have a problem with “set administrator/moderator” buttons that when I try to nominate a user for that i get:
ActiveRecord::RecordInvalid (Validation failed: Name has already been taken)
Any idea why and how could I solve this? Many thanks
(Régis Hanol) #2
Seems like you have 2 users with the same username (which might happen after an import depending on what validations you disabled).
(Cy) #3
It happens with all the users I try to nominate as mods or admins.
Do I understand correctly that 1 dupped user could cause that problem? If so could you please suggest a way of proceeding to solve the issue?
Many thanks @zogstrip
(Cy) #4
I’ve run:
[17] pry(main)> User.select(:username).group(:username).having("count(*) > 1")
and as you can see there seems not to be dupped users… Any hint @zogstrip zog?
(Cy) #5
I can’t seem to be able to solve this. Do you have any hints I would go for? Any help is really appreciated.
(Sam Saffron) #6
What is the backtrace?
(Cy) #7
I did a big import from vbulleting with about 60k users and 1M posts. Nothing else installed or hacked. Running on a Docker install. Is that what you’re asking @sam?
(Sam Saffron) #8
If you look in /logs there is a tab for a backtrace so we can see where this is coming from.
(Cy) #9
Thank you @sam and apologies and am still familiarising with terminology:
Here is the backtrace < Recent Message ActiveRecord::RecordInvalid (Error en la validación: Name - Pastebin.com
(Cy) #10
Have you had a chance to look at it @sam ? I can’t figure out anything clear from that log
(Manthan Mallikarjun) #11
ActiveRecord::RecordInvalid (Error en la validación: Name ya ha sido escogido)Share Protect
Error en la validación: Name ya ha sido escogido in english means Validation failed: Name has already been chosen. @zogstrip is right. It looks like there are two users with the same username.
(Cy) #12
That’s what it seems but how if you see post #4, the query returns nil. How could I identify that dupped user? Additionally if you keep reading, this error happens for EVERY SINGLE USER I try to get nominated
(Manthan Mallikarjun) #13
Maybe the SQL statement is wrong? I have no idea. Sorry.
(Cy) #14
Maybe it’s better then not to reply to the topic?
(Jeff Atwood) #15
This whole topic is a cluster, because it is a failed import. Who knows what state your database is in.
(Cy) #16
The import didn’t through any errors so I assume it wasn’t corrupted. The forum is up and running. Everyone is happy except for that only bit.
It there any way to run a consitancy check and repair whatever is broken then?
(Kane York) #17
Nobody ever built that, because we never needed to. ActiveRecord is doing on-the-fly consistency checks as the data is accessed, and it seems the checks are failing.
(Cy) #18
That’s correct. Even if I trigger manually the DBCONSISTENCYCHECK at the sidekiq scheduler and it’s the only “FAILED”
I must say that I didn’t hack anything in special at the import script or forum, so I wonder how that corruption could happen and if it happened to other people too that uses the same import script (bundled in)
(Cy) #19
Is there anyone with enough knowledge on this? I am happy to pay for this service and also I’d contribute the fix to the community.
Many thanks
(Cy) #20
As an update, I could manually enable their admins with:
u = User.find_by_email("their@email.com")   <-- I also tried and worked with find_by_username
u.moderator = true
u.activate
u.save
The curious thing is that the DB nor the command line didn’t complained at all??
When I trigger the EnsureDBConsistency job I get this backtrace:
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/validations.rb:57:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/attribute_methods/dirty.rb:29:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/transactions.rb:273:in `block in save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/transactions.rb:329:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:209:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/transactions.rb:208:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/transactions.rb:326:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/transactions.rb:273:in `save!'
/var/www/discourse/app/models/group.rb:136:in `refresh_automatic_group!'
/var/www/discourse/app/models/group.rb:149:in `block in refresh_automatic_groups!'
/var/www/discourse/app/models/group.rb:148:in `each'
/var/www/discourse/app/models/group.rb:148:in `refresh_automatic_groups!'
/var/www/discourse/app/jobs/scheduled/ensure_db_consistency.rb:8:in `execute'
/var/www/discourse/app/jobs/base.rb:153:in `block (2 levels) in perform'
