Can't rebuild: logster locked to 1.2.10
(tran) #1
When I installed the chat plugin “babble”,app rebuilded successfully.But when I changed the language to Chinese,the web crashed. So I had to delete the babble hook and rebuild the app but fail.the error info as Follow:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4' failed with return #<Process::Status: pid 282 exit 7>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
c70650de738ba85b221ea09abfd2ee11f5ee8749727025958569982e481032a8
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
(Alan Tan) #2
Please provide us with the full trace.
(tran) #3
Looking up gems ["descendants_tracker", "axiom-types", "coercible", "equalizer"]
HTTP GET https://index.rubygems.org/info/descendants_tracker
HTTP GET https://index.rubygems.org/info/axiom-types
HTTP GET https://index.rubygems.org/info/coercible
HTTP GET https://index.rubygems.org/info/equalizer
HTTP 200 OK https://index.rubygems.org/info/descendants_tracker
HTTP 200 OK https://index.rubygems.org/info/axiom-types
HTTP 200 OK https://index.rubygems.org/info/coercible
HTTP 200 OK https://index.rubygems.org/info/equalizer
Looking up gems ["ice_nine", "adamantium"]
HTTP GET https://index.rubygems.org/info/ice_nine
HTTP GET https://index.rubygems.org/info/adamantium
HTTP 200 OK https://index.rubygems.org/info/ice_nine
HTTP 200 OK https://index.rubygems.org/info/adamantium
Looking up gems ["memoizable"]
HTTP GET https://index.rubygems.org/info/memoizable
HTTP 200 OK https://index.rubygems.org/info/memoizable
Your bundle is locked to logster (1.2.10), but that version could not be found
in any of the sources listed in your Gemfile. If you haven't changed sources,
that means the author of logster (1.2.10) has removed it. You'll need to update
your bundle to a different version of logster (1.2.10) that hasn't been removed
in order to install.
now I delete the babble hook,app can rebuild successfully but the web show “HTTP ERROR 500”
(Alan Tan) #4
Try rebuilding again. This should have been fixed.
(tran) #5
I had rebuilt 4 times,the resuilts were all successful,but the web showed “http error 500”. I installed the babble many times,if I chose chinese, discourse crashed and can’t restored every time. Does this plugin don’t support Chinese?
(Alan Tan) #6
This error that you’ve provided has been fixed in
