Can't reply to topics in 2.5.0.beta2 ( c97244ca11 )
In my forum https://forum.rclone.org/ it appears that we can’t reply to topics
This has a relatively plain install with 3 official plugins.
The backtrace is
NoMethodError (undefined method >' for nil:NilClass) /var/www/discourse/lib/post_creator.rb:473:in update_topic_auto_close’
/var/www/discourse/lib/post_creator.rb:473:in `update_topic_auto_close'
/var/www/discourse/lib/post_creator.rb:183:in `block in create'
/var/www/discourse/lib/post_creator.rb:366:in `block (2 levels) in transaction'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:281:in `block in transaction'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:281:in `transaction'
activerecord-6.0.1/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/lib/post_creator.rb:365:in `block in transaction'
/var/www/discourse/lib/distributed_mutex.rb:33:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:29:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:14:in `synchronize'
/var/www/discourse/lib/post_creator.rb:364:in `transaction'
/var/www/discourse/lib/post_creator.rb:174:in `create'
/var/www/discourse/lib/new_post_manager.rb:271:in `perform_create_post'
/var/www/discourse/lib/new_post_manager.rb:209:in `perform'
/var/www/discourse/app/controllers/posts_controller.rb:179:in `create'
actionpack-6.0.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-6.0.1/lib/abstract_controller/base.rb:196:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack-6.0.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport-6.0.1/lib/active_support/callbacks.rb:135:in `run_callbacks'
actionpack-6.0.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport-6.0.1/lib/active_support/notifications.rb:180:in `block in instrument'
activesupport-6.0.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-6.0.1/lib/active_support/notifications.rb:180:in `instrument'
actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord-6.0.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-6.0.1/lib/abstract_controller/base.rb:136:in `process'
actionview-6.0.1/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-2.0.1/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
actionpack-6.0.1/lib/action_controller/metal.rb:191:in `dispatch'
actionpack-6.0.1/lib/action_controller/metal.rb:252:in `dispatch'
actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:51:in `dispatch'
actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack-6.0.1/lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:837:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
rack-2.0.8/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.0.8/lib/rack/conditional_get.rb:38:in `call'
rack-2.0.8/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:318:in `call'
rack-2.0.8/lib/rack/session/abstract/id.rb:259:in `context'
rack-2.0.8/lib/rack/session/abstract/id.rb:253:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/cookies.rb:648:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-6.0.1/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-6.0.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster-2.7.1/lib/logster/middleware/reporter.rb:43:in `call'
railties-6.0.1/lib/rails/rack/logger.rb:38:in `call_app'
railties-6.0.1/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:18:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:22:in `call'
rack-2.0.8/lib/rack/method_override.rb:22:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.0.8/lib/rack/sendfile.rb:111:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/host_authorization.rb:77:in `call'
rack-mini-profiler-2.0.1/lib/mini_profiler/profiler.rb:312:in `call'
message_bus-2.2.3/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:181:in `call'
railties-6.0.1/lib/rails/engine.rb:526:in `call'
railties-6.0.1/lib/rails/railtie.rb:190:in `public_send'
railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing'
rack-2.0.8/lib/rack/urlmap.rb:68:in `block in call'
rack-2.0.8/lib/rack/urlmap.rb:53:in `each'
rack-2.0.8/lib/rack/urlmap.rb:53:in `call'
unicorn-5.5.3/lib/unicorn/http_server.rb:605:in `process_client'
unicorn-5.5.3/lib/unicorn/http_server.rb:700:in `worker_loop'
unicorn-5.5.3/lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
unicorn-5.5.3/lib/unicorn/http_server.rb:144:in `start'
unicorn-5.5.3/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
infobacktraceenv Solve  Remove  Protect  Copy Share
 Debug
 Info
  Warning
  Error
  Fatal
The first code link is to discourse/post_creator.rb at c97244ca115c6e8d287d9c4e6033bf3e1d084f70 · discourse/discourse · GitHub which appears that topic_timer.duration is nil.
I think this might have happened at a recent upgrade
I tried rebuilding the app from the command line but it didn’t change anything.
Any help much appreciated!
Just noticed that this doesn’t occur on all topics, but the ones it does occur on say at the bottom “This topic will close a few seconds after the last reply.”
“A few seconds after the last reply”? That looks like a setup issue to me, these topics would be closed extremely quickly, so it’s not surprising you can’t post a reply?
We’ve had the same settings for months and the only change was the update that was done today.
I tried chaning the auto close timers in the top settings but no change.
I just noticed the little trash can saying delete timer next to the “A few seconds after the last reply”
Clicking that then makes posting OK.
I think this must be a bug… This has been working fine for ages and stopped working after the update to 2.5.0.beta2 today.
Anyone have any ideas on how to fix this? A bit of DB massaging maybe?
Might be related to @vinothkannans recent changes?
Yes, we already have a fix in the below open PR. It will be merged on Monday.
Thank you for that!
I fixed our db up with the SQL from the above. So be precise I did
Enter the postgres command line
cd /var/discourse
./launcher enter app
sudo -u postgres psql discourse
at the postgres prompt enter the SQL from the above migration. I didn’t do the first SQL part as there weren’t any matching entries.
UPDATE topic_timers SET duration = EXTRACT(EPOCH FROM execute_at - created_at) / 3600 WHERE duration IS NULL AND execute_at IS NOT NULL AND created_at IS NOT NULL;
This fixed the problems!
Thank you for your help
