Can't select a Badge for my Title
(cpradio) #1
On the Preferences page, click on Title, the drop down is empty :frowning: I can’t select one of my badges to use as a title, it always states: No matches found.
(Mittineague) #2
Mine isn’t “technically empty” but a dropdown of a Search input that doesn’t “find” any of the Badges.
OK, same thing I know. :wink:
I guess it should either present with select options for those available or find those available.
(Jeff Atwood) #3
Were you awarded any badges that are valid titles? Not all badges are allowed to be selected as titles.
(Mittineague) #4
Ah, that likely explains it. I didn’t realize the setting had to meet criteria.
(cpradio) #5
Which badges have titles?
(Jeff Atwood) #6
You will have to ask @sam how to determine that as a user, I have no idea. Admins can edit the characteristic of the badge to either have a title or not.
(Sam Saffron) #7
OK, this is fixed :v:
  • Leader can now be used as title badge
  • Amended the user page only to allow you to select a title if you have more than 0 badges that can be used as titles.
Proposed rewording of badge property text on badges page
(Sam Saffron) #8
