Can't update setting, getting gateway timeout eveytime
(Naveed Ahmad) #1
Discourse version: v1.7.0.beta7 +84
Facing timeout only for updating any system setting. Creating post, replying actually everything is working fine. So issue is not traffic which is slowing down the response time. Any suggestion ?
thanks
(Felix Freiberger) #2
Are you using the default Docker-based install? Are you running Discourse behind a proxy?
(Naveed Ahmad) #3
Yep using default Docker based install.
