Can't use 1 existing tag
(Carlo Kok) #1
I’m admin on our forum and have an existing tag “delphi” that somehow can’t be used anymore. When entering it it doesn’t show in the popup, nor does it let me “create” it by pressing enter. (Topics tagged delphi) what could cause this? There’s nothing in the logs or browser error log.
(Mittineague) #2
Was it this that happened?
(Carlo Kok) #3
ah! trying an update now (4 days behind). Thanks
(Rafael dos Santos Silva) #4
Update won’t work, that PR hasn’t made into the code yet.
In the meantime, go to Topics tagged delphi and remove the tag from first deleted topic it was applied.
(Carlo Kok) #5
ah thanks, but that url isn’t working (as admin), does this need to be enabled first? (Just shows all the regular data)
(Rafael dos Santos Silva) #6
Ouch, my bad.
You will need to get to the rails console and search there:
TopicTag.joins(:tag).where(tags: {name: 'delphi'}).pluck(:topic_id).first
This will give the topic ID with the tag. Visit https://talk.remobjects.com/t/ID to remove the tag.
(Carlo Kok) #7
curiously enough, that’s Local service - Hydra - RemObjects Talk which isn’t actually deleted.
(Rafael dos Santos Silva) #8
Did you change any tag related settings?
Isn’t it exclusive to a new category by mistake or something like that?
(Carlo Kok) #9
ah!that was it (very hard to find). went through all categories one by one till I found it. Thanks
