Category Authorship Transfer?
(Jeffrey Keefer) #1
I will be creating the default categories in our new community I am building, though each one will actual have somebody else as the main facilitator. Is there a way I can transfer category ownership to the facilitator so that their name and avatar will appear instead of mine?
Thank you!
#2
  1. Press the wrench icon at the bottom of the thread and select Select Posts
  2. Hit the Select button and select the first post of the About thread.
  3. Click the Change Ownership button.
  4. In the box that comes up, type in the username of the person who should own the category. Make sure to select it from the dropdown!
  5. Click the Change Ownership button.
Done!
(Jeffrey Keefer) #3
Thank you, @KazWolfe; very helpful!
