Category not always applying
(AstonJ) #1
This has happened a few times now - I’ve posted a thread but the category doesn’t seem to associate (I have to move to a different category then back again).
When clicking on the thread and the edit icon next to the title - the category is actually showing! Very weird :confused:
Also, a few times on posting a new thread the ‘you must choose a category’ notice shows even tho there’s already one present.
Any ideas what might be going on? Has it happened to anyone else?
(Allen - Watchman Monitoring) #2
I’ve seen this on my hosted instance in the past two days.
After creating the topic, moving into a different category (then back again if needed) let the category display properly.
(Wes Osborn) #3
Are you can admin for your forum?
If so, then you’re most likely experiencing this issue:
(TechnoBear) #4
I think it’s probably related to this discussion:
(AstonJ) #5
Forgot to say that the ‘post to uncategorised’ feature is set to off. (But when I am posting, it actually has the right category selected.)
(Sam Saffron) #6
Yeah I know this bug
Select2 is displaying lies we got to fix it, there is a separate report of this elsewhere
Multi-select to change category doesn't work
(Allen - Watchman Monitoring) #7
For now, from a permissions & sorting point of view, is the actual category shown in the edit mode being respected? (or is it important to do the category reset dance to make it look right).
