Category of Topic won't change?
I tried to change the category of a Topic which is not pinned or archived or any of that.
When I try to save the change it just resets to the same old category. I tried multiple other categories and it won’t work.
Any assistance will be appreciated please.
Hello!
Is it a Discourse’s default category or topic?
No, it’s one we created.
There’s only one topic in your category, but Discourse always creates a “About this category” topic by default. This topic can’t be deleted or moved to another category.
My guess is that you renamed and unpinned this default topic. :slight_smile:
You can be sure of that by checking the first post’s edit history. The first version should have some placeholder text including:
(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters.)
Understood. Will do thank-you.
