Category Subtitle
Hi there,
Is there a way to add a short subtitle under a category title to describe the sort of content that is permissible. E.g.
Category title: Member Intro’s
Subtitle: Introduce Yourself, Tell Us About Yourself
Any help would be appreciated. Thankyou.
This is what the “about the category” topic that is automatically created is used for. As soon as you edit the first paragraph of the first post in that topic it will be displayed in the category index as well as on the tooltip if you hover the cursor over a category name.
I am fairly certain it should be possible to have that tooltip permanently visible as a subtitle if you modify your design a bit, but I don’t have the know-how to tell you the magic custom CSS code to make that happen :grimacing:
