Centering images
(Rafael Solci) #1
Hi, i was loonking into more formmating options and stuck with a problem with centering things in a post.
<center></center>
Works nice on texts.
Like this
But when i put emoji or images within center tags, its breaks
This text is centered, and this emoji :D should be also centered
If i put an image link discourse doesn’t even embed the image.
Also, is there anywhere i can find the formatting options?
Thanks
(Jeff Atwood) #2
Center should not be an allowed tag, anyway. @eviltrout can you make sure that’s not on the HTML whitelist please?
(Rafael Solci) #3
may i ask why?
center do something bad to de code or something? will be a way to center elements in the posts without this?
(Jeff Atwood) #4
It is unnecessary and irritating, like the blink tag. Markdown has no concept of centering.
(Luke Larris) #5
Does that mean centering text and other elements will not be available in Discourse?
(Sam Saffron) #6
It means that out-of-the-box we will not have it enabled. But, as always, on your forum your rules apply.
(Rafael Solci) #7
While not agreeing with the centralization be something annoying, I’ve read more about the definition of markdown and agree with you on that part.
Thanks of the information :smile:
(Robin Ward) #8
Sure, it's fixed now.
(Allen - Watchman Monitoring) #9
So - I’m trying to showcase an image in a post I’m making.
How does one go about centering an image in a discourse post?
(Kane York) #10
Text text text
Watchman Monitoring
Text text text
<div align=center><img src="https://d11a6trkgmumsb.cloudfront.net/user_avatar/meta.discourse.org/watchmanmonitor/45/18154.png"><br>Watchman Monitoring</div>
(Eric Trowbridge) #11
Works perfectly - thank you @riking!
(system) #12
