Change outgoing SMTP settings for notification emails in discourse.org hosted forum
In the hosted version, the invites and other notification emails are sent out from “@discoursemail.com”. Is it possible to use a custom FROM address. I can’t find where I can edit the outgoing SMTP settings.
Thanks
It is possible if you are on an enterprise hosting plan.
Otherwise it is not possible.
