Changing limit_req of nginx
Hi,
I am running discourse v2.1.0.beta4 +6 with the docker installation on an Ubuntu 16.04 with 2CPUs and 4GB of RAM.
This is no heavy load forum, the average load is 0.11 0.06 0.01.
But sometimes when I visit the site, the html page is not correctly formatted. It looks like CSS files are missing.
I took a look inside the container and I am wondering, if it is nginx, that stops issuing files - I get messages like this in the error log:
2018/05/11 23:04:12 [error] 310#310: *4831 limiting requests, excess: 12.044 by zone "flood", \
       client: ....., server: _, request: "GET /t/name-of-issue/647 HTTP/1.1", host: "....."
It seems like it is due to the limit_req settings in /etc/nginx/conf.d/discourse.conf. Can I change these settings without them being overwritten after an update? Or what would be the requested way to deal with that problem?
A little off topic - how do you see your boards loading times?
This is not actually the loading time but the system load of the underlying Linux system.
This usually means you are passing the IP through the stack incorrectly so your site (and thus Discourse) sees all requests as coming from the same IP address.
Hi Jeff, thanks a lot for the pointer. But this does not seem to be the case. The nginx/access.log has a lot of different client IPs in it.
What is the recommended way to change nginx/conf.d/discourse.conf to be update resistent?
By persisting the modifications in the app.yml, so the changes get applied on each rebuild of the container.
Thanks a lot, but this does not seem to solve my problem.
Again the stylesheets are missing. The page looks like this:
Looking at the network of the browsers developer mode everything looks fine. There are no failed requests.
Only two CSS are loaded:
https://community.privacyidea.org/stylesheets/admin_ca1a1bc842ff312ef0262dfa29af3e1f7abacd53.css?__ws=community.privacyidea.org
https://community.privacyidea.org/mini-profiler-resources/includes.css?v=251162ee7dc30da30d5370581c664510
This time I look into the nginx error log and it is empty.
The access log only has HTTP 200 OK.
After restarting the container everything is fine - for a while.
