Changing options on wp-discourse plugin via wp-cli
(Keith John Hutchison) #1
G’day
How do you change the wp-discourse plugin options via the word press command line?
For example.
How would you change the wp-discourse options url and the api key via the wp command line?
(Simon Cossar) #2
Enter the wp shell with wp shell. You can see all the plugin’s options by running:
wp> WPDiscourse\Utilities\Utilities::get_options();
The options are stored in arrays, based on which of the option pages they are saved on. You can find the names of the arrays with:
wp> get_option('discourse_option_groups');
The API key and Discourse URL are stored in the 'discourse_connect' array. You can update them with something like this:
wp> $connection_options = get_option('discourse_connect');
Make the changes you want to make to the returned array, then run:
wp> update_option('discourse_connect', $connection_options);
(Keith John Hutchison) #3
Many thanks for your guidance Simon.
This is what I ended up doing.
Created a file called activate-wordpress-plugins.php which I called from the command line with
    /usr/bin/wp --allow-root --path=/var/www/html eval-file /var/www/html/activate-wordpress-plugins.php
The contents of activate-wordpress-plugins.php follows.
<?php
echo('Getting discourse settings' . "\n" ) ;
$connection_options = get_option('discourse_connect') ;
echo('Setting discourse url to ' . getenv('DISCOURSE_URL') . "\n" ) ;
$connection_options['url'] = getenv('DISCOURSE_URL') ;
echo('Setting discourse api key to ' . getenv('DISCOURSE_API_KEY') . "\n" ) ;
$connection_options['api-key'] = getenv('DISCOURSE_API_KEY') ;
echo('Updating discourse settings' . "\n" ) ;
echo( update_option('discourse_connect', $connection_options) ) ;
where DISCOURSE_URL and DISCOURSE_API_KEY are valid environment variables.
(system) closed #4
