Changing the code text color
(Simplism) #1
I’m trying to change the code text color to a pink, how can I do this?
(Jay Pfaffman) #2
/admin/customize/css_html
In the CSS section:
p>code, li>code, pre>code {
    color: pink;
Though I think that `#f0f` is a better color of pink.
(Simplism) #3
Hi, that doesn’t seem to work.
(Simplism) #4
I created a new CSS thing called “code” and pasted that, no effect.
(Jay Pfaffman) #5
Well, I just copied and pasted that on my site and it worked. Can you point to a page on your site that has code?
(Also, you can click the pencil to edit a post)
(Simplism) #6
http://185.133.73.136/t/this-is-a-test-of-the-system/11
(Simplism) #7
That changed the entire background
(Jay Pfaffman) #8
Well, you’ve deleted the page now, so I can’t look. Here’s what that looks like on my site:
Not sure why it’d be different on yours, but then again, this is nearly the first Discourse CSS I’ve managed to tweak.
(Simplism) #9
Only wanted to change the text @pfaffman
(Simplism) #10
http://185.133.73.136/t/this-is-a-test-of-the-system/11/2 I can see it. Here is what I did:
(Simplism) #11
New post: http://185.133.73.136/t/code-test-for-jay/14
(cpradio) #12
Make sure you enable the customization. (checkbox at bottom of screen)
(Jeff Atwood) #13
This enabling thing is a giant pain in our :horse: @sam and has resulted in way too many support requests.
(Sam Saffron) #14
I know the UI needs a revamp, but the alternative is to allow for a single customization that is always enabled
(Jeff Atwood) #15
We urgently need a UI fix here. Maybe a dialog nagging people to enable if they edit? Something, anything, the way it is now is a disaster.
(Felix Freiberger) #16
I’d guess that enabling them by default would already be enough.
(Daniela) #17
I’d prefer a button “Enable” (not a flag to add or remove) instead enable by default. Most people play with their customizations and the preview before enabling the changes.
A proposal:
(Jeff Atwood) #18
Whichever one of these you like, you should do @sam, this is your :baby: monster.
(Sam Saffron) #19
I am redoing this whole UI, no point fiddling with it now.
