Chat-integration
Hello Community!
I see a lot of chat-integrations available,
I’m hoping to get some feedback from users on what ones are great,
I need a great one, one that can handle some traffic
and, could any be placed in a post,
i.e. could this post “host” the plug in, or will they all require a side box?
Thanks to anyone that can help
Robert
It might be helpful for you to list the ones you’re considering - the official “discourse-chat-integration” plugin does not allow embedding chats inside discourse. Instead, it sends notifications from Discourse to an external chat system.
The official is what I have,
  • Enable the discourse-chat-integration plugin
but there are a lot under it:
  • Enable the slack chat-integration provider
  • Enable the Telegram chat-integration provider
  • Enable the Discord chat-integration provider
  • Enable the Hipchat chat-integration provider
  • Enable the Mattermost chat-integration provider
  • Enable the Matrix chat integration provider
  • Enable the Zulip chat integration provider
With webhooks and other things that look like work to set up, so I hoping for some
good advice on which one is worthwhile,
They are all separate, correct?
Thanks you for the reply
Robert
You can find instructions for all of them here:
I’m looking to run a chat for an hour each day to run concurrent with an online call in show,
are any of those recommended/able to accomplish this?
The idea, people listen to the show, chat about it on our site, preferably in a designated sub category.
Much like youtubes live chat feature.
