Chrome stable required for Android app?
I have downloaded several Chrome stable releases but still get the same error.
Is a Google account required to use the Discourse app?
Or can anyone provide a non-googleplay link to a chrome release that will work?
here is an alternative website to download the APK for chrome.
https://www.apkmirror.com/apk/google-inc/chrome/
Thanks that’s what I’ve been using.
As an update: I’ve successfully installed it on a stock Samsung S5 Neo without a Google account.
It still won’t work with Android 5 and an updated stable chrome release.
That site lists 100s of versions.
Can you link to a version that will definitely work?
Thanks for the super prompt response btw
The most recent one which supports your OS version (check APK description) should work just fine.
Yes, Chrome stable is required. There’s already a topic about this.
Yep:
I know but what does that mean?
I’ve got chrome stable as far as I know and it still doesn’t work?
What is chrome stable? And what is the exact version number or a direct download link (not Google Play)?
That’s the thing it just doesn’t and I’ve tried several versions including those said to be stable.
