Click on “Reply” sometimes without effect
#1
On our forum running v1.8.0.beta5 +106 we’re seeing the same thing as discussed here:
I don’t really have much info to add because it sounds like the same bug. I also don’t really know how to reproduce - it doesn’t happen every time, but it happens enough that we’ve had to list it in a “known bugs” post and tell people to copy the post and refresh.
One - possibly anecdotal - interesting thing, is that since we moved from Azure to a locally based host, it seems to be happening quite a bit less.
Since we cloned the whole thing to move it, the only real difference is having much lower latency to the server now.
(Jeff Atwood) #2
I have never seen this, so reclassifying to support until you have repro.
(Sam Saffron) #3
If you (or anyone on the forum) can figure out a consistent set of steps to repro we can sort it out.
Need the exact browser version and sequence of events, keep in mind you can inject delays into your network using chrome dev tools.
