Code-fence and <pre> formatting require preceding blank lines to render correctly in cooked
(PJH) #1
Continuing the discussion from Hyperlinking email addresses in monospaced formatted text:
From the linked topic:
Cooked and preview seem to be having a disagreement about something (preview was my intended/preferred layout, with the CRLF’s):
HTML not escaped in topic titles on /my/activity/posts
(Jeff Atwood) #2
@sam is this related to your recent changes to enable the <table> hack?
Let’s see
This should
be on three
different lines
and with backticks
This should
be on three
different lines
Nope that’s not it, i guess it has to do with URLs?
http://example.com/1
http://example.com/2
http://example.com/3
and with backticks
Nope that’s not it maybe it has to do with HTML style hyperlinks?
<a href="http://example.com/1">one</a>
<a href="http://example.com/2">two</a>
<a href="http://example.com/3">three</a>
and with backticks
Nope all looks fine…
I’m kind of unclear what the repro is here @pjh?
(PJH) #3
Replacing mailto with http:
`­`­` (code fence):
<a href="http://a.example.com">a.example.com</a>
<a href="http://b.example.com">b.example.com</a>
<a href="http://c.example.com">c.example.com</a>
<pre>:
a.example.com
b.example.com
c.example.com
(PJH) #4
Preview (bottom right) is what I’d expect.
Cooked (top center) is what I’d not.
(Jeff Atwood) #5
I think this is because the URLs match the link text. That’s my hunch? Let’s try:
<a href="http://example.com/one">http://example.com/one</a>
<a href="http://example.com/two">http://example.com/two</a>
<a href="http://example.com/three">http://example.com/three</a>
(PJH) #6
Sorry - Instead of copying #3 and replacing mailto: with http:// to see if that was the issue, I ended up editing #3.
Seems to not matter anyway…
(PJH) #7
Nope:
`­`­` (code fence):
<a href="http://a.example.com">http://a.example.com</a>
<a href="http://b.example.com">http://b.example.com</a>
<a href="http://c.example.com">http://c.example.com</a>
<pre>:
<code>:
(PJH) #8
No idea what the differences are…
Copy/paste from raw of yours:
From mine:
`­`­` (code fence):
From mine with extra CRLF:
`­`­` (code fence):
(PJH) #9
Ah. There it is. Those are the only two that require an extra line feed between the previous line and start of markup to make cooked match preview.
(Jeff Atwood) #10
So backtick code blocks require a blank line above them, otherwise they don’t respect linebreaks as expected. Is that it then? If so can you edit the title to reflect?
(PJH) #11
It appears so.
Done.
(Sam Saffron) #12
this
is
now
   fixed
   yay
<pre>
   except
   that
   a
   pre
   in a code block is messed up... but I can fix that as well
</pre>
https://github.com/discourse/discourse/commit/568adc49c09c4964ef3168dfd1fa12c2fb05203b
Fixed pre in block hoisting, but lots of ways to hoist code, so probably a few edge cases left
(Sam Saffron) #13
