Code for centering videos and photos in topics/posts horizontally
G’day,
I have this code (thanks to III) to center photos horizontally and would like to do the same for embedded videos of all types.
/*center images uploaded to posts*/
.lightbox-wrapper {
    display: block;
    text-align: center;
p>img {
    display: block;
    margin: 0 auto;
Does anyone know the best (broad, applies to all embedded video types) code for horizontally centering videos?
Thanks in advance.
Videos uploaded to Discourse will be centered by default. Videos from external services like Youtube / Vimeo will almost always be within iframes, So if you want something very general you can try something like this:
.cooked>iframe {
    display: block;
    margin: 0 auto;
.lazyYT.lazyYT-container {
    margin: 0 auto;
To center both Youtube videos specifically - these are handled differently in Discourse - and act as a catch-all for all other embedded videos.
Do note that this is a very general rule and will cause all iframe elements to be centered - which in this case is generally harmless.
A slightly more specific way is to target certain services that are most likely to be used. You can do something like this:
.cooked>iframe[src*="player.vimeo.com"] {
    display: block;
    margin: 0 auto;
And this will only have effect on iframes from vimeo instead of styling all iframes.
You can read more about attribute selectors here
Worked like a charm, Joe. Thanks.
