&Colon ; gets reverted when posted
(from TDWTF) #1
If you type : into your editor, it shows up as : on the preview, shows up as : for a second and is then reverted into it’s : state when submitted.
Steps:
  • Start a Topic / Reply
  • Type in :
  • Watch the preview display “:”
  • Submit your post
  • See the “:” in your post
  • Watch it transform into :
Rebaking doesn’t help either, thanks @boomzilla
Filed Under: Once again, not mission critical but still a bug
Addendum: all other tested html-entities seemed fine. Did not go through a complete list, though
(Jeff Atwood) #2
It’s really a duplicate of ℵ ℵ which is an upstream Nokigirl bug. Find the other bug this is a duplicate of, or you can open one bug on every entity Nokogiri messes up…
(Jeff Atwood) #3
(Sam Saffron) #4
