Command-G for Upload?
(Peter N Lewis) #1
What happened to Command-G for Upload in the message composer?
(Jeff Atwood) #2
I dunno, is there an editor hotkey for upload @eviltrout? Tooltips do not indicate there is…
(Peter N Lewis) #3
It appears to have disappeared between 1.4.6 and 1.5.1 (I have an automation that relies on it (since Pasting images doesn’t work in Safari) so I noticed its absence pretty quickly).
(John ) #4
Some discussion here:
(Robin Ward) #5
Yeah the issue here is finding a unique key for it. Cmd+G won’t do. See the above topic.
(John ) #6
There needs to be an international agency for licensing keyboard shortcut space.
(Kane York) #7
CASA - Computing Assigned Shortcuts Association
(Peter N Lewis) #8
I don’t understand that. Its ok to take over Cmd-F (which if Edit ➤ Find, used in all applications on the Mac), but you’re not happy to take over Cmd-G (which is Edit ➤ Find Next, used in all applications on the Mac). If you take over Cmd-F, then Cmd-G is useless since you can’t enter the search in the first place…?
Help us test the rewritten Composer
(Jeff Atwood) #9
Totally different discussion, because find ain’t gonna find shit when we only load 20 posts at a time in the browser and you are expecting to “find” something in reply 67. This is also only done on topics with more than 20 replies.
(Peter N Lewis) #10
OK, fine, in the absence of a replacement keystroke, is there a JavaScript command that will work? I can trigger some JS in response to a hot key of my choosing.
(Jeff Atwood) #11
Just help us find a replacement in the other topic and we should be good.
