Composer is attempting and failing to load the markdown-it-bundle resource under http
(Stan Dyck) #1
I have a site configured to accept http and https connections. When I start a topic under https, the composer is attempting and failing to load the markdown-it-bundle resource under http which causes the preview to fail.
I’m not sure how this should behave but it currently just silently fails.
Help us test a new composer style
(Régis Hanol) #2
If https is working, why don’t you enforce it? There’s no point in serving both other than hitting these quirks…
(Stan Dyck) #3
I can enforce it but what if I’m in a situation where I can’t?
I think it’s incorrect for software to assume that http://foo/bar is the same resource and has the same representation as https://foo/bar (or file://foo/bar or somenewprotocol://foo/bar).
An https resource should especially not assume http://server/somelibrary.js is the same as https://server/somelibrary.js which appears to be the case here.
[I also don’t necessarily agree that there is no point in serving both.]
(Jeff Atwood) #4
This is an unsupported config. Either you are https enforced or you are http.
