Configurable items in hamburger menu?
#1
Is it possible to configure the items that show up in a user’s hamburger menu? I’d like to remove a few items from what my users see.
Thanks!
(cpradio) #2
If you outline what you want to hide, I can help you create the CSS Customization to hide them. A screenshot showing which items to hide will do wonders.
#3
Thanks!
I’d like to hide the items I have circled in this screenshot:
(cpradio) #4
.hamburger-panel a.about-link, .hamburger-panel a.faq-link { display: none; }
Simply add that to your Customizations > CSS section (make sure the customization is enabled), and be sure to add it to the Mobile view too by clicking on the mobile icon (top right).
If that doesn’t work right away, try using
.hamburger-panel a.about-link, .hamburger-panel a.faq-link { display: none !important; }
Cakeday! Celebrating birthdays and anniversaries
#5
That second one worked. Thanks!
#6
How about removing “users” from this menu, how can we do this?
(Nam Nguyen) #7
Hi, try this :wink:
.hamburger-panel a.user-directory-link { display: none !important; }
#8
Works fine.
Thanks :slight_smile:
