Confirmation Dialogs no body copy
(Jaimie) #1
I did a fresh install yesterday following the guide on DO. The confirmation dialogs do not have any content in the body section. For example if you cancel out of starting a topic. All that show is a dialog box with “Yes” “No”
Doing an inspect there is just an empty tag for the tag:
Is this a resource language issue?
(Sam Saffron) #2
Fixed yesterday as well,
If using our docker guide go to /admin/docker and upgrade.
(Jaimie) #3
I just tried this but got an error, post here:
https://meta.discourse.org/t/beginners-guide-to-deploy-discourse-on-digital-ocean-using-docker/12156/102?u=puzle&source_topic_id=13242
(Sam Saffron) #4
let me guess … you are running on a 1GB digital ocean setup ? You need more memory.
Stop the site and rebootstrap as documented in guide.
(Jaimie) #5
I did follow the guide but used the pictures more than reading it fully so yes I have 1GB.
I think that the guide should show the 2gb option selected so that other might not bump into the same problem.
And perhaps update the copy to say “Discourse requires a minimum of 1 GB RAM, and 2 GB RAM is recommended if you want to be able to use the web based docker upgrade path.”
Thanks for the help.
(Jeff Atwood) #6
