Correction for french invite translation
(Doctor Who) #1
Hello,
I’m actually using on Digital Ocean : Discourse 1.2
I make test and got a problem with french invite template email. There are some mistakes I wish to correct.
So :
  • Where could I improve for Discourse french translation for be integrated in next release ?
  • Before the next automatic update, how could I correct this in my actual Discourse installation ?
Best
(Régis Hanol) #2
We host all of our translations on transifex.
I’m actually not sure, @techapj, you got any ideas?
(Arpit Jalan) #3
There’s a plugin by @lidel which allows manual override of translations, have a look:
(Doctor Who) #4
Ok i’ve register and repair the mistake, it’s done now :slight_smile:
Ok I will try it and do a feedback as soon as possible
(Doctor Who) #5
I’m back.
@techAPJ, I’ve download improved french traduction from transifex
Then clone plugin repository : https://github.com/Doctor-Who/discourse-locale-override
Then add following line to the containters/app.yml
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone https://github.com/Doctor-Who/discourse-locale-override.git
and rebuild app but … invitation still have wrong version …
In the app.yml, should I edit file
env:
  LANG: en_US.UTF-8
to
env:
  LANG: fr_FR.UTF-8
or doing it from Discourse admin in default_local is enough ?
Thanks for your help
(Arpit Jalan) #6
Setting the default locale to fr from admin settings should be enough.
(Doctor Who) #7
ok @techAPJ so I’ve got no idea why it’s not working … :frowning:
(Arpit Jalan) #8
@lidel can you have a look here?
(Marcin Rataj) #9
Hm… sadly I don’t have any idea beside the fact that french translation at Transifex starts with fr_FR:
https://github.com/Doctor-Who/discourse-locale-override/blob/52be04181fede2c68612f281a3992fb142e9543d/config/locales/server.fr.yml#L1
while in Discourse sources fr is used (yes, this in no typo – probably some kind of script does this conversion automatically):
@doctorwho please try to change first line in your custom translations to fr:
- fr_FR:
+ fr:
Hope this helps.
Unable to upgrade, button disappear on DigitalOcean
(Mittineague) #10
Wouldn’t it be better to change “fr” to “fr_FR” to allow for other French dialects?
French - Belgium	fr_BE
French - Canada		fr_CA
French - France		fr_FR
French - Luxembourg	fr_LU
French - Switzerland	fr_CH
I’m guessing they could all “figure it out” well enough, but just the same, it would be more “professional” IMHO
(Doctor Who) #11
@lidel It works ! This is amazing ! Thank you so much !
Why not :slight_smile:
