Crashed my discourse while changing settings in admin section
Hi guys,
It seems I crashed discourse while changing some settings related to categories
Initially I was trying to remove all options from Top menus. As I was getting an error saying that I can’t remove “latest” from top menu, I changed “category style” to “Categories only”. Then I removed all top menus. However my discourse became really unstable and finally I ended up getting “Error 500”.
In the nginx logs, I can see some “connections refused”. We tried rebuilding the container, restarting the whole machine. nothing worked.
Any idea?
Thx
Seb
It’s pretty simple, the first entry in the top menu is also the ‘home’ when you visit / - if you were able to remove everything from that list (which shouldn’t be possible, right?) then your site would no longer have a default page to serve up.
Changing the desktop category page style only does that, the style of the categories page, which isn’t necessarily the page served from the root (/).
From my phone I can’t check how you revert that setting, although I’m pretty sure it can be done. Wiser minds than mine can interject on that front.
@steve_pd Thanks for pointing @sebastien and I in the right direction.
We were able to fix the problem by going directly to the docker container and opening a rails console. In the rails console we reset SiteSetting.top_menu to “latest” and that fixed the problem :slight_smile:
Some old topics about this: Top Menu Removal Crashes Site
and https://meta.discourse.org/t/home-page-404s-if-top-menu-is-garbage/15513
and Deleting all entries from top menu results in 500 error
https://meta.discourse.org/t/home-page-404s-if-top-menu-is-garbage/15513/2
Apparently never got implemented?
I warned about it the other day when I replaced this kind of inputs with select-kit, sorry it got lost, probably should have created a bug issue about it.
discourse/string_setting_validator.rb at master · discourse/discourse · GitHub is returning before regex_match? if value is nil. So in the case where you remove all values it’s never hitting the regex validation.
Not sure how to fix this as we have settings like ga_universal_tracking_code which rely on this behavior:
  ga_universal_tracking_code:
    client: true
    default: ''
    regex: "^UA-\\d+-\\d+$"
We will validate it once user enters one setting, otherwise we bypass validation. We could add a site setting option valid_blank: true, what do you think @neil ?
As a temp fix to your issue you can do the following:
in your /discourse
bundle exec rails c
SiteSetting.top_menu = "latest"
It should fix the error.
Just make it so that the validator is okay whenever the regex matches OR the setting has its default value.
No need to add any options then.
That’s a possibility, not sure it will cover all the cases though, hence why I’m asking neil who knows the subject more than me.
Since this is a list setting, maybe an option to have min number of items in the list?
Maybe but if the only item in the list is a weird one, it may still not work.
