Crawler and self-signed certificates
(Richard Dern) #1
Hello fellows,
First: thanks for this great piece of software, and thanks for making it free :slight_smile:
Next, I just have one issue: how to make the crawler parse my feed, which is on a website with self-signed certificate ?
(Jeff Atwood) #2
Which crawler are you referring to?
(Richard Dern) #3
Sorry, I should have been more explicit.
I want to embed discourse on my website. I set up everything, including the Atom feed, in Admin > Customize > Embed and put the js code on my posts pages, but as I’m using a self-signed certificate for this site host (which is obviously different from the host on which I host discourse), I have this error in my logs:
Started GET "/embed/comments?embed_url=https%3A%2F%2Fwww.athaliasoft.com%2Fcyca-mon-projet-laboratoire" for 127.0.0.1 at 2016-01-20 23:52:55 +0000 Processing by EmbedController#comments as HTML Parameters: {"embed_url"=>"https://www.athaliasoft.com/cyca-mon-projet-laboratoire"} Rendered embed/loading.html.erb within layouts/embed (0.4ms) Completed 200 OK in 8ms (Views: 1.3ms | ActiveRecord: 3.2ms) Job exception: SSL_connect returned=1 errno=0 state=SSLv3 read server certificate B: certificate verify failed
(Matt Palmer) #4
Oh, the fun of TLS…
DIscourse uses the system’s trust store when verifying certificates. The correct way to install a new trust anchor in the store is to add something like this to your app.yml configuration file:
run:
    - file:
        path: /usr/local/share/ca-certificates/atomfeed.crt
        chmod: 0444
        contents: |
          -----BEGIN CERTIFICATE-----
          MIICm<etcetcetcetcetc>
          -----END CERTIFICATE-----
    - exec: /usr/sbin/update-ca-certificates
(That’s an untested, off-the-top-of-my-head example; test it somewhere unimportant before unleashing it in production)
The certificate you add can either be the self-signed certificate itself, or else a CA certificate which issued the certificate(s) you want to trust (directly, or through an intermediate CA certificate).
Installing self-signed CA for Omniauth
(Richard Dern) #5
I get the jist, but I lack of luck.
I put your snippet in my app.yml, only replacing cert content by the cert used by the feed’s website, then my CA’s cert.
I also tried the same but changing the file path to /etc/ssl/certs/.
Oh I forgot to mention, after each test I did ./launcher rebuild app.
Each time, during the build, I can see:
I, [2016-01-21T02:49:47.296440 #37] INFO -- : Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done.
But not sure if it means the cert have already been added or if it was not at all, I can’t see any error at this point. But discourse’s log keeps showing me the same error as in my second post here.
I think we’re close :slight_smile:
(Richard Dern) #6
Ok I made it to work. I placed my CA cert in /usr/local/share/ca-certificates/, works like a charm.
Thank you very much !
(Richard Dern) #7
Well, at least:
I, [2016-01-21T03:31:29.832760 #37]  INFO -- : File > /usr/local/share/ca-certificates/Athaliasoft.crt  chmod: u=r,g=r,o=r
I, [2016-01-21T03:31:29.837672 #37]  INFO -- : File > /usr/local/share/ca-certificates/www.athaliasoft.com.crt  chmod: u=r,g=r,o=r
I, [2016-01-21T03:31:29.838235 #37]  INFO -- : > /usr/sbin/update-ca-certificates
I, [2016-01-21T03:31:31.407814 #37]  INFO -- : Updating certificates in /etc/ssl/certs... 2 added, 0 removed; done.
But it still have this error:
Job exception: hostname "www.athaliasoft.com" does not match the server certificate
(Matt Palmer) #8
That’s a whole different thing… the certificate still needs to be issued for the name you’re connecting to, otherwise it’ll never work. You may have to issue a different certificate, or access the service by a different name (one that is contained in the certificate that is being presented).
(Gerhard Schlager) #9
I recommend you buy a certificate or use a free certificate from Let’s Encrypt. It will make your life a lot easier.
(Richard Dern) #10
That’s the point, my certificate matches the domain name of the website.
(Richard Dern) #11
A certificate from an external CA ? hehe, not gonna happen :slight_smile:
(Felix Freiberger) #12
It looks like your certificate does not:
SSL Labs diagnoses the same issue:
(On a side note, your server is vulnerable to the POODLE attack. This is bad – you should fix this as soon as possible!)
I’d reconsider that – getting a proper certificate from Let’s Encrypt is easier than generating a proper self-signed certificate…
(Richard Dern) #13
Ok, thanks for pointing out the vulnerability.
But I’m confused about the cert name and the server name. Aren’t they the same ? Is it the alternative name that causes my troubles ?
And about the CA: I don’t want things to be easier, I want things MY way :slight_smile:
(Felix Freiberger) #14
I don’t know – being a user of CA-issued certificates, I never had to care :slight_smile:
(Matt Palmer) #15
The CN of a certificate is only examined if there is no subjectAltName extension. As soon as a sAN is found, CN is completely ignored. You’ll need to re-issue that cert with both names in the sAN if you want it to work for both names.
(Richard Dern) #16
Ok thanks, I’ll do that and let you know.
Thanks for your time !
(Richard Dern) #17
All right, I re-issued my cert as you suggested, now it works as intended.
And I solved the POODLE issue.
Thanks you all very much :slight_smile:
