Crawler View still shows Tags when Tags are disabled
(Pirat) #1
I popolzovatsja these tags
and I realized that they were with bugs and errors
Karoche saying if you use these tags and then want to stop you will have a bunch of non-existent pages
I think to remove the plug-in is crude
Sorry for the translation :slight_smile:
or it needs to be updated
(cpradio) #2
I haven’t a clue what you are suggesting. Tagging is built into core now, so the plugin is no longer needed. When you upgrade Discourse, you getting tagging built in, and it is compatible with the data the tagging plugin created… so you won’t have non-existent pages.
(Pirat) #3
Include tags and create a post with tags
Then disable the tags in the admin panel
Then go to the website without javascript
and you will see links to tags
(cpradio) #4
Ah, okay, so that does seem like a bug of some sort. And that’s a much clearer set of repro steps :slight_smile:
Screenshot of problem
(Pirat) #5
I am glad that you understand :slight_smile:
(Jeff Atwood) #6
IMO this is not a bug. You added a tag, then disabled tags. That leaves things in an indeterminate state. Remove the tag on the topic.
(Pirat) #7
and if the tags pieces 1000000 :slight_smile:
finger gets tired delete
