Create Group And categories (One time both name is same)
Create Group And categories (One time both names is the same)
I want first to create the group and then create Categorie with this group permissions.
this process is at one time.
So make a group and then make a category. Go to the security of the category and select it so only the group can create /reply / see
thanku for response but i done this work
hi this is mainly group related
With a single action, you want to create a group and a category with settings related to the group?
I think it’s not possible unless you create a custom script for that.
