Create Topic category selection not on screen
(Dean Taylor) #1
When the browser window is resized down to ~800x600 the category list is hanging off-screen.
Everything else about the size appears to work correctly at this size.
As a quick work and dirty around I added this to the desktop CSS:
#reply-control.edit-title .contents input#reply-title {
	max-width: 42vw;
#reply-control .contents .form-element .category-combobox {
	max-width: 45vw;
Possible related topic:
Create topic title and category inputs too small on Nexus 7
(Michael Downey) #2
IIRC there are official minimum resolutions, and 800x600 is below it.
I couldn’t find the topic about it. Just saw it the other day, though.
(Jeff Atwood) #3
Try searching for minimum width, it is result #4 for me.
The rules on this have changed since then, though, as @awesomerobot made the design more responsive to narrower widths.
(Kris) #4
Yeah, I must have overlooked that… right now the layout works below 800px, so that dropdown should too. Will fix.
(Jeff Atwood) #5
