Creating a discourse setup
Hi all,
When I execute the discourse-setup it returns an error containing this: i.imgur.com/JaYOSiY.png.
I can ensure that the domain points to my VPS and that the firewall allows port 80 and 443.
I have also followed this post step by step.
This is my Nginx config:
Any help would be greatly appreciated.
If you’re using a reverse proxy you can’t use discourse*setup. You’ll need to edit the app.yml file by hand. How to use Docker multiple containers without exposing ports might help. You can search for other instructions.
