CSS class of “saving” bar?
Looking for the CSS class of the bar that appears when your reply/post is saving. It disappears too fast to inspect. Anyone know what it is?
Try #reply-control.
If you want to target that bar specifically when the post is saving, you want:
#reply-control.saving
If you want to target it when you have a minimized draft as well, you want:
#reply-control {
  &.draft,
  &.saving {
    // Add your customizations here
Nothing working so far… hmmmmm…
Can you post the full CSS code that you tried? Those are definitely the correct ids/classes.
Works. Turns out had to go with background-color instead of just color.
