CSS / Header Styling
Hello, We are using code below to update css/header for mobile to display an additional icon, next to search-icon:
<script type="text/discourse-plugin" version="0.4">
api.decorateWidget('header-icons:before', helper => {
return helper.h('li', [
    helper.h('a#home-button.icon', {
        href:'https://help.appybuilder.com/',
        title: 'AppyBuilder Help Docs'
        ,target: 'helpDoc'
    }, helper.h('i.fa.fa-question-circle-o.home-button-icon.d-icon')),
</script>
However, on smaller screen sizes, the icons wrap on 2nd line:
Is there any suggestion on how to handle this (e.g. auto-remove the help (?) icon when space is limited OR use smaller fa icon?
To checkout: community.AppyBuilder.com
Thanks
You can either remove the icon, or make the icons smaller — it’s a matter of preference. It’s helpful to ask yourself how important that link might be to a mobile user. If it’s important, you might prefer to keep it.
An easy way would be to make all the icons a little smaller, you’d do it like this:
@media screen and (max-width: 425px) {
  .d-header-icons {
    font-size: 0.9em;
You might need to experiment with the value a little bit. 0.9em might work, or you might need to go smaller.
To remove the icon entirely you’d want this:
  a#home-button.icon {
    display: none;
@awesomerobot Thanks for your reply.
Should that code be added in side the script?
You’d want to add it to your theme’s mobile CSS:
Admin > Customize > Themes (select your current theme) > Edit CSS > Mobile > CSS
@awesomerobot You are good :+1: Took the 1st approach for making it smaller
THANKS
