CSS help reply button
Hi everyone!
I’m configuring my site, but in the mobile view I have this overlap.
I’m not a big expert in css, i tried to put down the controls/reply button but i can’t…
sorry for the newby question, but is there any code to move down a little bit those buttons? thanks!!
That doesn’t look right. The topic-progress component should automatically undock once you’ve scrolled to the bottom of the topic.
You might have some conflicting custom CSS that’s causing the issue.
Can you share a link to the site you’re seeing the issue on so we can have a look at what’s causing it?
Thanks for your quick reply @johani :slight_smile: I have actually solved the issue after trying a lot!
There are definitely certain scroll positions that cause this. I see it a fair bit.
