CSS - No "Do not include standard style sheet"?
(PJH) #1
There used to be a checkbox under /admin/customize/css_html > CSS/HTML labled “Do not include standard style sheet”
Has it disappeared or simply moved elsewhere?:
Before:
Now:
(Robin Ward) #2
I believe @Sam removed this feature as it was causing problems. Maybe he can jump in here with more insight and a possible workaround.
(Sam Saffron) #3
Yes, I removed it, never seen it used in the wild and its super risky and makes upgrading a nightmare.
(PJH) #4
Hmm. Well I was going to offer it as an option over on ours - and I have in fact linked to one such in the past.
I presume the only way of emulating it is to initial everything that is currently set?
(Sam Saffron) #5
It would be a giant task maintaining a complete base stylesheet, its just way too much work, even just getting the composer to work would be a 100 line job.
