CSS Persistent change
Hi,
So I am new to discourse my question is how can I edit css so that say all my buttons have rounded corners but have that applied across updates to which ever theme I am using ?
I went to edit css and it says that it will revert if any updates are applied to the theme.
To that end I would also like to change the colours of buttons
Create a new theme component in your admin, add this theme component to your current theme(s) and edit your theme component CSS.
.btn {
    border-radius: 5px;
If you want to change the buttons colors, you can either change your theme color scheme or target the button you want to change with CSS.
Example:
.btn-primary {
    background: red;
