Css to hide topic timeline per topic
(Paul W) #1
I’m trying to hide the topic timeline, essentially trying to create a fullwidth page.
I only want to do this on one specific topic.
I’ve fairly easily found a css selector for the body
section[data-topic-id="77"] .topic-body {
  width: 100%;
but I can’t find a css selector to apply to #topic-timeline (or #topic-progress-wrapper), just so I can display:none
Can anyone help?
(Joe) #2
Take this with a grain of salt.
You won’t be able to do so with pure CSS.
CSS is cascading, meaning the direction it follows is always down the document tree.
.timeline-container comes before the element with the attribute data-topic-id and that’s why you won’t be able to select it with pure CSS based on the presence of the data-topic-id
You can do this with jQuery but the implementation I know for Discourse is not very efficient as it will fire on every single page load which is nonsense if you’re only trying to change one page.
(Paul W) #3
yep … knew all that :confused:
Kinda hoping someone has done something like insert topic-id into the body class :thought_balloon:
(Paul W) #4
How about someone savvy with the api ?
$('body').addClass('topic' + ${topic.get('id')})
p.s. I know nothing :stuck_out_tongue:
(Daniela) #5
Probably if you play with z-index you can hide the timeline without using jQuery
.timeline-container have z-index: 499 , so you can use 500 for .topic-body.
If you do not want avatar positioning problems use a 90% width instead of 100% and obviously use a white background
Something like this should work:
    width: 90%;
    background:white;
    z-index: 500;
