Current MySQL database of users
(Cedric Meirsman) #1
Hello,
Currently we have a MySQL database (server) containing the user names and passwords encrypted in whirlpool.
Is there a possibility to integrate with Discourse? So that users can directly log in and if necessary further data deposits.
Thanks in advance!
(Kane York) #2
I believe that @michaeld has a login transition plugin?
(Michael - DiscourseHosting.com) #3
Yes, but you would need to build whirlpool support in GitHub - discoursehosting/discourse-migratepassword: Support migrated password hashes and worse: create the users in advance.
Another solution would be to set up a simple SSO implementation around the MySQL database, and delegate authorization to it.
