Current user id in plugin.rb
(Joe Buhlig) #1
I apologize if I’ve placed this in the wrong category as I’m new to Discourse and meta.
I’ve been working on a development version of Discourse and I’m really loving the application. I’m working to build an integration with Braintree, but part of the process requires me to get the user_id of the current user. I couldn’t find any documentation on how to call the User object from Ruby. There’s a number of cases that show how to do this on the Ember side, but I couldn’t find any on the Rails side. I’m probably just being dense and I’m missing something simple, but my brain can’t see it.
(cpradio) #2
Based on
It seems to just be current_user
(Alan Tan) #3
In your controllers, you can get the current user with current_user
(Joe Buhlig) #4
Doh! I knew it was simple, but just couldn’t see it. I was trying to pull it with the model for some reason. Thank you much!
(Joe Buhlig) #5
I’m still missing something. It still tells me that current_user is undefined. Any ideas on what’s still missing? I thought I understood how Discourse was doing this, but apparently it’s more complicated than I thought. This is in plugin.rb.
PLUGIN_NAME = "braintree_integration".freeze
after_initialize do
  module ::BraintreeSetup
    class Engine < ::Rails::Engine
      engine_name PLUGIN_NAME
      isolate_namespace BraintreeSetup
  require "current_user"
  require_dependency "application_controller"
  class BraintreeSetup::SetupController < ::ApplicationController
    puts current_user.user_id
(Régis Hanol) #6
You can only access current_user inside an action.
(Alan Tan) #7
It might help if you read through this Action Controller Overview — Ruby on Rails Guides. :smiley:
(Joe Buhlig) #8
The action part makes sense. Is there an easy way to run the action from there? I’ve tried before_action on it, but it fails. This is something I’ll want to run every time the user logs in.
Thanks for the article, @tgxworld. I’m definitely new(ish) to Rails.
(Joe Buhlig) #9
Well, I think I’m a failure at Rails. I’ve built a few Rails apps before and never had this much trouble.
I have a Ruby API that I’m trying to pass the user_id into. It’s all server side, so I don’t think Ember applies. I want to validate an account through the external api with the user_id and based on the result, alter whether the user has access to a group or not. I don’t need anything passed to the interface.
I’m not sure a controller is needed as I don’t have a view involved. It’s a really simple process if I can get the user_id.
Anyone willing to save the day?
(Mittineague) #10
I’m not clear on what you’re doing so you may be right.
I was experimenting a while back with getting user info and when I stopped had this in an es6 file.
    if(Discourse.User) {
      if(Discourse.User.current()) {
        Discourse.User.current().findDetails().then(function(u) {
where user info can be accessed inside the function like
u.last_seen
(Joe Buhlig) #11
I was able to do that part. My head at least works on that side. I just haven’t succeeded in running it entirely in plugin.rb every time the page loads. I’m now exploring a Sidekiq job possibility.
(Kane York) #12
Well, in what contexts do you have a “current user”? You don’t have one when the plugin is starting up & defining stuff, you only have it during a request…
(Joe Buhlig) #13
@riking You’re awesome! That’s exactly my problem. I was thinking about it wrong. It makes a lot more sense to run a Sidekiq job that does all the work. Thank you for helping me think differently!
